  2. Functional Verification
  3. Help: vr_ad sequence expansion error
  • Subscribers 67
  • Views 14718
MukundVerif
MukundVerif over 16 years ago
I have a e-specman testbench. When I load testcase, while loading the sequence library I am getting the following error message though there is no syntax error.
Error: No such variable 'do_item__dma_tb_sequence_lib_1931__'
#   at line 219 in
# /var/source/e/vr_ad_eVC/v2.3/vr_ad/e/vr_ad_macro.e
#          do op keeping {it == op<?>};
#   expanded at line 1314 in *.sequence_lib.e
at this line no 1314 in sequence_lib.e i have write_reg().
I am not sure if it is tool issue or memory issue while loading. I am getting this error only when I run regression (using lsf). If I run single regression this error is not reported.
Mukund
  • StephenH
    StephenH over 15 years ago
    Hi Mukund.
    Did this code load OK before? If so, what changed (tool version, vr_ad version, your own code)?
    What does the write_reg() invocation look like?
    Steve
