  2. Functional Verification
  3. why ! is used while declaring instances in specman
  • Subscribers 67
  • Views 15048
LATHEESH
LATHEESH over 15 years ago
Why ! is used while declaring instances in specman,
!add: add_type;
what is the difference between using ! and not using it.
  • tpylant
    tpylant over 15 years ago
    The "!" is used to denote items that should not be pre-generated (randomized). This would typically be used for a field such as parity that you would use a method to compute and assign or an object that you would want to generate procedurally.
    import sbt_packet.e;
    extend sys {
       packet1: sbt_packet_s;
       !pkt: sbt_packet_s;
       run() is also {
          gen pkt;
          for j from 0 to 2 {
            gen pkt keeping {
              it.addr == j;
              it.len < 20;
