  2. Functional Verification
  3. vr_ad reset check
  • Subscribers 68
  • Views 16081
vr_ad reset check
Ravisinha
Ravisinha over 15 years ago
Hi all, When we define as vr_ad reg_fld for each reg_file we used to provide the reset value of each field. As i know the application for this is when we call reset() function for that reg_file it will overwritten with a reset value whatever we have assigned. My doubt here is can it be use for doing a reset check.. For example whenever i do a read of some register i need not to provide the extra check method in my code for checking the reset value and it should be done automatically with vr_ad compare_and_update() method w.r.t the reset value of corresponding reg_def. Thanks Ravi
  • StephenH
    StephenH over 15 years ago
    Hi Ravi.
    vr_ad doesn't explicitly cover or check for reset values, however if you reset a register and subsequently read it before writing it, then the value you read and check will be the reset value. In this case vr_ad will be checking the reset value implicitly.
    If you look at the vrad/examples/vr_ad_reg_sequence_lib.e you'll find some helpful pre-defined register sequences. For example the CHECK_RESET_VALUES sequence will go through all the registers checking their reset values. You can evenoverride the list of registers so that the sequence checks only a specific subset of the registers, or you can use it to force the order of checking.
    If you need some coverage to tell whether a register's reset value was read, you could easily extend the base vr_ad_reg with a new boolean field that gets set TRUE by the reset() method, and cleared after covering its value in post_access(). Thus when the flag is covered TRUE you know you've checked the reset value for that register.
    Hope this helps.
  • Ravisinha
    Hi Stephen, Thanks for the quick reply. Now i understood.. And one more point i want to add here is ; basically in environment we have to add like on each transaction end (monitor event) , based on READ/WRITE we should called update(addr,data,mask) and compare_and_update(addr,data) method of vr_ad. If we do this way whenever we read any register vr_ad will check it automatically with the current updated value. thanks
  • tauf
    tauf over 13 years ago
    Hi Stephan, I am writing sequences for vr_ad, I found predefined sequences such as reset check and random read and write. However unable to find writing FFFFFFFF & 00000000 to all registers in def file like walking pattern or bit bash etc.
    Can you please guide me how to write this, as I try to declare one more filed in random read write sequences as FFFFFFFFF data, but it,s not working.
    Please post me this sequence so that can move forward
    I am doing something like this
    for each (r) in reglist{
    do op keeping {
    .static_item=r;
    .direction == write;
    in the above code , have no idea how to add data field as 0xFFFFFFFFFF and 0X0000000000;
