  2. Functional Verification
  3. cross coverage between different vr_ad registers
  • Subscribers 67
  • Views 15294
lakku
lakku over 15 years ago
I am trying to achieve cross coverage b/w two different vr_ad registers, like when register -1 is accessed then i want to get the cross coverage on the register -2 fields.. (Assume that register2 is configured with some values before register-1 access)..  i tried many ways but i failed to see the coverage collection for such items..
Please let me know whether it is possible?? If not is it possible to get the cross coverage on diffrent register fields?? My coverage scenario is as follows..  Need solution for this
Ex scenario:
extend  vr_ad_reg {
   event reg_1_e;
extend REG2 vr_ad_reg {
  cover reg_1_e is {
   cross REG2_FLD1,REG2_FLD2,REG2_FLD3;
extend REG1 vr_ad_reg {
 post_access(direction : vr_ad_rw_t) is only {
    if direction == READ {
       emit reg_1_e;
  • StephenH
    StephenH over 15 years ago
    The example you posted won't work because there is one reg_1_e event for each instance of vr_ad_reg, it's not one event shared across all struct instances.
    What you need to do is make a pointer to REG2 inside REG1, so that you can emit the event on REG2.
    Try something along these lines:
      event reg_1_e;
      cover reg_1_e is { ... };
      !p_reg2 : REG2 vr_ad_reg;
      post_access(direction:vr_ad_rw_t) is also {
        if direction==READ and p_reg2 != NULL {
          emit p_reg2.reg_1_e;
    extend MY vr_ad_reg_file {
      post_generate() is also {
        reg1.p_reg2 = reg2;
  • lakku
    Hi Stephen,
     Thank you very much for the solution . It is working now..
    Regards
    Lakku
