  2. Functional Verification
  3. Parameterized macros in sv
  • Subscribers 67
  • Views 18314
jzingman
jzingman over 15 years ago
I'm trying to write what I thought was a fairly simple macro in sv:
 `define DISPLAY  (value) `"INFO:    %0t value = %0x (%m)`", `$time, value
invoked by
  $display (`DISPLAY(bitcnt));
When I try it, I get a lot of error messages:
      $display(`DISPLAY(out_bitcnt));
ncvlog: *E,EXPRPA (flex_ssi_model.vi,432|22): expecting a right parenthesis (')') [10.2.2][14(IEEE)].
(`define macro: DISPLAY [flex_ssi_model.vi line 19], `include file: flex_ssi_model.vi line 432, file: ./flex_ssi_model.sv line 18)
ncvlog: *E,EXPCPD (flex_ssi_model.vi,432|22): expecting a valid compiler directive [16(IEEE)].
 Am I missing something obvious?  I'm running IUS92-s030 in Linux64 using the ncvlog/ncelab flow. The errors are in the ncvlog step.
 Jonathan Zingman
  • Shalom B
    Shalom B over 15 years ago
     It looks like there is a space in the macro definition between "DISPLAY" and "(value)". I think there should be no space.
     Also, it looks like there this is a "back-tic" ( ` ) before "$time". That should not be there.
    The use of `" seems unneeded. I think simple regular quotation marks are enough.
    I also don't remember whether NC supports the %x format.
    Shalom
  • jzingman
    Shalom:
    Thanks, but I don't think these are the issues.  White space shouldn't matter, but I'll try getting rid of the extra space.  I've tried it with and without the ` before $, so that isn't the issue. Also, according to the spec, to get a " in the expansion of the macro, you have to escape it with ` first.  Finally, I used a successful $display statement as the model, so, yes, NC appears to support %x.
     Jonathan
  • Shalom B
     Regarding the space after the macro name, the LRM says, "If formal arguments are used, the list of formal argument names shall be enclosed in parentheses following the name of the macro... The left parenthesis shall follow the text macro name immediately, with no space in between." That is how the compiler knows that the left parenthesis begins an argument list, and is not part of the macro text.
    You are correct, though, that you need `", but not for the reason you state. You need `" so that "value" will be substituted by the argument value.
    Shalom
  • jzingman
     My apologies.  It is sensitive to the white space as you point out, and once I got rid of it, I had to get rid of the ` before the $ as well.
