  2. Functional Verification
  3. Specman e: Configurable bus width and transfer generati...
  • Subscribers 67
  • Views 15903
Specman e: Configurable bus width and transfer generation
Steff
Steff over 15 years ago
Hi all,
I'm currently developing a bus UVC which shall support configurable bus widths (8, 16, 32, 64 bits).
For the configurable bus width I use the approach as described by StephenH on Verification Guild:
http://verificationguild.com/modules.php?name=Forums&file=viewtopic&p=8967
In short, I'm using defines for the maximum supported width and have a configuration parameter for the agent which contains the actual width.
Now my problem is that the struct containing the physical fields (e.g. address, data, size, byte strobes) doesn't know anything about the actual configured data width.
Example struct:
type xyz_bus_address_t : uint(bits:MAX_ADDRESS_BUS_WIDTH);
type xyz_bus_data_t : uint(bits:MAX_DATA_BUS_WIDTH);
type xyz_bus_size_t : [BYTE=0, HALF_WORD=1, WORD=2, DOUBLE_WORD=3] (bits:MAX_DATA_SIZE_WIDTH);
struct xyz_bus_data_item_s like any_sequence_item {
    %address : xyz_bus_address_t;
    %data : xyz_bus_data_t;
    %size : xyz_bus_size_t;
    -- Access to address offset +0 => byte, half word, word, double word
    -- No constraint for address offset +0
    -- Access to address offset +1,+3,+5,+7 => byte
    keep address[0:0] == 1 => size == BYTE;
    -- Access to address offset +2,+6 => byte, half word
    keep address[1:0] == 2 => size in [BYTE,HALF_WORD];
    -- Access to address offset +4 => byte, half word, word
    keep address[2:0] == 4 => size in [BYTE,HALF_WORD,WORD];
The constraining of the size done above is only valid in case a 64 bit bus is configured as a double word access might be generated randomly even if the bus is configured for a smaller width.
Now I'm not sure what to do.
Does the struct needs to get the actual bus width as a virtual field? I think this is ugly as the user always has to provide the actual size to a method when generating a transfer.
Or should I leave the physical fields in the struct without constraints (for use in a monitor) and generate the values of the actual transfer e.g. in the BFM on the fly as it knows the actual width?
Can you suggest me a best practice how to solve this problem?
Best regards,
Stefan
P.S.: I'm a beginner in Specman e so please be patient with me :-)
  • StephenH
    StephenH over 15 years ago
    Hi Stefan.
    Welcome to the world of Specman! :-)
    What I typically do is to have an enumerated type for the bus instance name, e.g.
    type xyz_bus_name_t : [XYZ0, XYZ1];
    The agent, montior, BFM and sequence driver would all be sub-typed using this enum, so that you can extend them by kind.
    The same applies to the sequence item. You can then put a constraint in the base sequence to constrain the item's bus_name to match the driver's bus_name.
      bus_name : xzy_bus_name_t;
    extend xyz_bus_data_item_s {
      when BUS0 {
        keep size in {BYTE;HALF_WORD};
      when BUS1 {
        keep size in {WORD};
    There may be other, better, ways to do this, but this works for me.
    Regarding randomising in the BFM, I would not recommend this; try to keep all the randomisation in the sequences if possible, otherwise you lose the controlability that sequences give you, and test writing becomes very difficult.
