  2. Functional Verification
  3. forcing a netlist path
  • Subscribers 68
  • Views 15395
Ravisinha
Ravisinha over 15 years ago
Hi, I have to force some signals inside netlist. When i see that signal full path in design browser i found that ":DUT:ve_core_inst:pss_top_inst:pss_top_inst.pss_ring_inst.pss_core_inst.pss_arcss_core_inst.ipss_cpu_isle.ipss_arc_ram_blk.iccm_memX12XXiccm_mem_8kXipss_iccm_rams.\U_pss_wrapper_iccm8kx32_int/U_pssram8192x32 .u0.PreloadFilename" Basically a mixture of ".(dot)" and "/". But if i use the same path to use for force its giving an error that path is not found. Can anyone let me know what is the issue ? Thanks
  • Ravisinha
    Sorry the path was wrong pasted in above post.. the actual path is like : :DUT:ve_core_inst:pss_top_inst:pss_top_inst.pss_ring_inst.pss_core_inst.pss_arcss_core_inst.ipss_cpu_isle.ipss_arc_ram_blk.iccm_memX12XXiccm_mem_8kXipss_iccm_rams.\U_pss_wrapper_iccm8kx32_int/U_pssram8192x32 .u0.PreloadFilename
  • PAULKI
    PAULKI over 15 years ago
    Hi Ravisinha,
    That is happening because of the flattened netlist format (from the synthesis tool). So better to align with the synthesis tool's format instead of the NCSim format. (instead of ":" try with the "/").
    Paul
