  2. Functional Verification
  3. How to pass arguments to ncsc_run just like you would pass...
  • Subscribers 67
  • Views 16345
How to pass arguments to ncsc_run just like you would pass arguments from the command line to a C program.
Matthieu P
Matthieu P over 15 years ago
Hi dear community members,
I'm trying to achieve the following:
- Just like if I were passing arguments to a C program called "myprog" and running ./myprog arguments and then parse the arguments in the code using argc and argv. I'd like to do the same when I use ncsc_run to simulate my SystemC environment.
- What I want to do is simple, I just want to give a value to one of my variables in one of my SystemC modules.
I went through cdnshelp and ncsc_run -help but I couldn't spot the answer to my problem. Any help is appreciated, thanks in advance.
  • muffi
    muffi over 15 years ago
    You can use the +systemc_args option with the ncsc_run
    #include "systemc.h"
    int sc_main(int argc,char *argv[) {
    cout << "argc = " << argc << endl;
    cout << "argv[0] = " << argv[0] << endl;
    cout << "argv[1] = " << argv[1] << endl;
    cout << "argv[2] = " << argv[2] << endl;
    cout << "argv[3] = " << argv[3] << endl;
    return 0;
    ncsc_run -sc_main +systemc_args+"x y z" test.cpp
  • Matthieu P
    Thank you very much!
