  2. Functional Verification
  3. Can +ams and +sv options be used together in ncverilog
  • Subscribers 67
  • Views 15936
Prachi1
Prachi1 over 15 years ago
I tried running this command:
ncverilog +ncams +sv test_module.v
Where test_module.v is my verilog file. I got the error that +ams and +sv options cannot be used together. Is there any way to use both these options together?
Prachi
  • tpylant
    tpylant over 15 years ago
    Use the 'irun' command and use filename extensions instead of broad switches.
      Irun test_module.sv test_ams.vams
    This will cause the SV compiler to be called for test_module.sv and AMS compiler for test_ams.vams.
    Tim
