  2. Functional Verification
  3. fork and automatic
  • Subscribers 68
  • Views 17387
fork and automatic
sevent
sevent over 15 years ago
 The followign code does not compile with ncverilog (the file has a .sv extension):
  foreach(i[idx])
  begin
    fork
    automatic string jdx = idx;
    begin
      run(jdx);
    end
    begin
      $display("jdx = %s",jdx);
    end
    join_none
  end
ncverilog gives:
 ncvlog: *E,UNSAUT (autoloop.sv,50|23): The 'automatic' keyword is not supported in this context.
  • TAM1
    TAM1 over 15 years ago
    That is legal code, but not supported yet by NC-Verilog. At the present time, the automatic keyword can only be put on a task or a function as a whole, not on individual elements in an always or fork-join block. I looked up the keywords "automatic fork join" on support.cadence.com and the first entry is a solution giving a workaround. Put the fork-join block into an automatic task. Then any variables declared for use in the block will be automatic.
      int i[string];
      task automatic run(input string runs);
        #2 $display($time,,"runs = ",s);
      endtask
      task automatic fjt(input string s);
        string jdx = s;  // this defaults to automatic
        fork
        begin
          run(jdx);
        end
        begin
          #1 $display($time,,"jdx = %s",jdx);
        end
        join_none
      endtask
      initial
      begin
        i["asdf"] = 1;
        i["xyz"] = 2;
        foreach(i[idx]) fjt(idx);
      end
  • laohan
    laohan over 15 years ago
    will ModelSim support this "automatic" keyword?
  • TAM1
    I haven’t seen the source code where you’ve used the automatic keyword. So it very well may be legal in the context in which it appears. There are several places where it is legal, but our simulator isn’t ready to process it yet. If you are trying to declare a variable local to a task or function automatic, try declaring the function as a whole automatic. I gave an example in the forum thread referenced in the link below.
    Tom Murray
    thomasm@cadence.com
