  2. Functional Verification
  3. How to interface Cpp code through DPI
  • Subscribers 67
  • Views 20832
archive over 15 years ago
I've been getting quite a few questions on this topic lately.  Here's one way to do it.  The main issue is that since all DPI is initiated by the simulator, if you use Cpp, then the complete SV <--> DPI <--> Cpp function call must be instantaneous.  This post describes a way to have your Cpp active throughout the simulation.
======file: top.sv =======================
package my_pkg;
import "DPI-C" function int dpi_build_cpp();
import "DPI-C" function void dpi_write_api(int n);
import "DPI-C" function int dpi_read_api();
endpackage // my_pkg
module top;
import my_pkg::*;
initial begin
  if (!dpi_build_cpp() )
    $display("Vlog: Cpp did not construct correctly\n");
  else
    $display("Vlog: Cpp ready to go\n");
  dpi_write_api(1234567890);
  #100ns;  // let some time go by
  $display("Vlog: Retriev Cpp member %0d", dpi_read_api() );
  else
end
endmodule
====file: dpi_cpp_api.cpp ======
#include "dpi_cpp_api.h"
// for vpi_printf
#include "vpi_user.h"
// for printf
#include <stdio.h>
// for cout etc
#include <iostream>
using namespace std;
// Class pointer  must be global - otherwise memory will be cleaned up after DPI call
mycpp_class* mycpp_class_inst = 0;
// #include <iostream>
//----------------C++ -------------------------
mycpp_class::mycpp_class() {
  cout << "Cpp: mycpp_class constructor" << endl;
mycpp_class::~mycpp_class() {
void mycpp_class::put_cpp(int x_cpp) {
  cout << "Cpp: put_cpp = " << x_cpp << endl;
  mycppint = x_cpp;
int mycpp_class::get_cpp() {
  cout << "Cpp: get_cpp\n" << endl;
  return mycppint;
//-----------------C/DPI wrapper----------------
extern "C" {
int dpi_build_cpp() {
  // check to see if class has been new-ed yet, if not new it
  if (mycpp_class_inst == 0) {
      mycpp_class_inst = new mycpp_class();
      vpi_printf("DPI-C: Cpp interface to DPI ready to go\n");
      return 1;
  else {
      vpi_printf("DPI-C: Please don't call me twice\n");
      return 0;
void dpi_write_api(int xx_c) {
  vpi_printf("DPI-C: dpi_write_api = %0d\n", xx_c);
  mycpp_class_inst -> put_cpp(xx_c);
int dpi_read_api() {
  vpi_printf("DPI-C: dpi_read_api returning value\n");
  return mycpp_class_inst -> get_cpp();
}  // extern C
===File: dpi_cpp_api.h ======
class mycpp_class {
public:
  mycpp_class();    // constructor
  ~mycpp_class();  // destructor
  void put_cpp(int xyz);
  int get_cpp();
 private:
  int mycppint;
=====3 Step Script============
  more RUN3
rm -rf  ./INCA_libs *.so
g++ -g -m32 -fPIC -shared -o dpi_cpp_api.so \
-I. -I./c_src -I`ncroot`/tools/inca/include  \
./dpi_cpp_api.cpp || exit
ncvlog -sv -linedebug top.sv  || exit
ncelab top -dpiheader mydpi.h || exit
# -uselic IES for Cpp debug in Simvision
ncsim top -sv_root ./ -sv_lib ./dpi_cpp_api.so -uselic IES
=====irun Script==============
rm -rf INCA_libs
rm *.so
irun top.sv -line -dpiheader mydpi.h -g -I.-cpost "dpi_cpp_api.cpp" -end -uselic IES
 =========Simulation Output==============================
ncsim> run
DPI-C: dpi_write_api = 1234567890
Cpp: put_cpp = 1234567890
Vlog: Retriev Cpp member DPI-C: dpi_read_api returning value
Cpp: get_cpp
1234567890
ncsim: *W,RNQUIE: Simulation is complete.
ncsim> exit
  • vujaclyn
    vujaclyn over 5 years ago
    What is the flag -m32? If I use this flag, I'm getting incompatible /usr/lib64/libssl.so.
  • StephenH
    StephenH over 5 years ago in reply to vujaclyn
    -m32 is an option to the GNU C compiler asking it to produce binaries in 32 bit mode. Without that, on a 64-bit system you get 64-bit binaries by default.
    Xcelium defaults to 32-bit compilation because it runs faster than 64-bit, however sometimes CAD environments force Xcelium into 64-bit mode either by adding the 64-bit bin directory to PATH or by setting an environment variable CDS_AUTO_64BIT.
