  2. Functional Verification
  3. Do $shm_suspend and $shm_resume work?
  • Subscribers 67
  • Views 16652
abiamb
abiamb over 15 years ago
My simplified code:
#100 $shm_open;
$shm_probe(...);
#100 $shm_suspend;
#100 $shm_resume;
#100 $shm_close;
Expecting waveform dump from 100 to 200 and 300 to 400 but getting dump from 100 to 400.
Anything that I missed?
  • TAM1
    TAM1 over 15 years ago
    No, they don't work. $shm_suspend and $shm_resume are left over from the Verilog-XL days and are ignored by the NC-Verilog simulator.
  • abiamb
    Thanks for confirming my suspicion.
    I used to do this type of window dumping in VCS and want to do the same in NC-Verilog.
    Being new to NC-Verilog, which PLIs to use to achieve the same thing? (suspend/resume waveform dumping).
  • TAM1
    The current version of the SHM database is pretty optimized, so the savings of turning off the dumping may be less than you expect. You can use the old $recordvars or $dumpvars routines. Both have an on and off function associated with them. You can also use the TCL probe -shm, probe -disable and probe -enable commands in a TCL script to turn dumping off and on.
