  2. Functional Verification
  3. Clock phase and frequency checkers using property
  • Subscribers 66
  • Views 21210
ThinkTank
ThinkTank over 14 years ago
Hi ,
I am working on a code to check clock frequency and phase difference of clocks. The code is in verilog however SV features are utilized wit the help of -sv switch.
I have a CLK and CLB and i want to check their frequencies as well as check if they are 180 degrees phase apart ,I have done in the following fashion , however this checker spans across 3 always blocks and one property definition .Please suggest if there is a better and shorter way to do this.
always @ (posedge CLK)
begin
assert property (clock_check(EXP_PERIOD));
end //this checks clock frequency of CLK
always @(posedge CLB)
begin
assert propertty(clock_check(EXP_PERIOD));
end // this would check frequency of CLKB
always @(posedge CLK)
 begin
    assert CLKB = ~ CLK;
end //This would check that they are 180 degrees out of phase
property clock_check (int EXP_PERIOD)
int start_time
(true,start_time = $time) |=> ($time - start_time == EXP_PERIOD);
endproperty
I have multiple clocks to check and the propert clock_check is utilized across all the checks.
Thanks ,
 Pooja
