  2. Functional Verification
  3. Code Coverage with ICCR
  • Subscribers 66
  • Views 18496
livid
livid over 15 years ago
 Hello
I am using ICCR 10.20-s043 in the gui mode to view the coverage data that i have generated for a sub-block embedded deep in the top level design.
In the ICCR gui mode, i can view the coverage for each instance and the cummulative total.
The problem i am having is how to generate this view as a text file ??
Frm the command line i have run iccr and tried the various "report_summary - ..." commands, but i am not able to get a text file which matches the view in the iccr gui.
Any thoughts on this ?
J.OSmany
    archive over 15 years ago
    If possible you should be using IMC to view coverage and generate reports.
    For ICCR you need to create a command file something like this:
    iccr iccr_rpt.cmd
    ---file: iccr_rpt.cmd----
     load_test  ./cov_work/design/testname
    report_summary -inst *... \
    -all -betsafd  \
    /iccr_summ_rpt.txt
    report_detail -inst *... \
    -all  \
    ./iccr_detail_rpt.txt
     report_html -inst *... \   <--- get all tops and underlying hierarchy
    -all betsafd \
    -output my_html_rpt.html
    For IMC, you can do something like this
    imc -barch imc_rpt_cmd
    ---file: imc_rpt_cmd---
    load ./cov_work/design/testname
     report -summary -inst *... \
    -metrics all  \
    -out  ./imc_summ_rpt.txt  \
    -cumulative on \
    -showempty on
    report -html -inst *... \
    -metrics all  \
    -out  ./imc_holes_rpt.html  \
    -overwrite \
    -showempty on
