  2. Functional Verification
  3. Using arrow keys in NCSim Tcl Command-line interface
  • Subscribers 67
  • Views 15303
Almendrico
Almendrico over 15 years ago
Hi all,
I believe it is not possible to use the arrow keys to navigate through the command history within the Tcl command-line NCSim console. Is this correct ?
The only approximate option I have found is using the tcl command "history", but this is not useful compared as the power given by the arrow keys...
So what I wonder is, is there any reason why this option is not avalaible ? Maybe I am misunderstanding the way I should be runnign simulations ? I mean, maybe I should be using an approach in which there was no need to use the console, using instead a self-checking  sim approach ?
This arrow keys option is implemented in the simvision GUI console thou, so not sure what to think ...
Any thoughts on this ?
  • Almendrico
    Actually, it is possible, just found it out !
    Need to use the "-e" command option when calling irun !
