  2. Functional Verification
  3. Passing a timing file in ncsim instead of ncelab
  • Subscribers 67
  • Views 15750
mcheah
mcheah over 15 years ago
 I am currently passing a timing file to disable timing checks when running sims with SDF back-annotation through the -tfile argument for irun.
 However, because of how our test environment is setup, I would like to only selectively disable certain timing checks depending on what macros are defined (e.g. +define+SDF1 and +define+SDF2 would use some different and some overlapping timing check disables).
I am wondering whether timing files can be passed on only after ncelab or is there a workaround to this issue?
 Thanks very much in advance.
Melvin
