  2. Functional Verification
  3. Gate level Simulation
  • Subscribers 67
  • Views 16966
Mandate
Mandate over 14 years ago
Hi All,
I am using Candence IES tool, and also new to cadence tools.
What are the inputs required for GATE level simulation (after synthesis)?
I have standard library file in .v format and .v netlist. Is this enough for gate level simulation?
Please help me in this
Thanks, Sam
  • tpylant
    tpylant over 14 years ago
    You’ll also need a testbench and a SDF file if you want accurate timing.
    Tim
  • Mandate
     Hi Tim,
    With testbench I tried simulatiing the synthesiszed netlist without SDF file. It gave approximately 0.7ns clock to q delay. I think, it is taking only the gate delay from the standard cell library and It doesn't have the net or path delay.
    Would like to know whether my understanding is correct?
    Is SDF file output of synthesis process - Cadence Encounter(R) RTL Compiler ?
    Very much appreciate your reply
    Sam
  • Mandate
     Hi Tim,
    Sam
  • tpylant
    Synthesis can you give you approximate delays but actual delays come after place & route.
    Tim
