  2. Functional Verification
  3. simulation preformence issue specman with C golden mode...
  • Subscribers 67
  • Views 14943
simulation preformence issue specman with C golden model
myonlyscreen
myonlyscreen over 15 years ago
 Hi all
I looking for advise on a preformance issue i am having.
I doing verification of a PHY module with specman and using a golden model of the design for checkers & debug aid.
over the time to ease the debug we exposed signals from the C model and injected them to signals in the test-bench via specman port .
in that we were able to look at waves both on the RTL signal and its equivalent reference signal.
all the simulation and the management of the C model is done by specman.
how ever we reached a sum of 7000 ports that specman inject from the C reference model , its realy slows the simulation.
after running profiler we saw that most of the time the cpu is busy in "flushing ports at end of tick".
i will be glad to hear some ideas on how to overcome this performance issue .
for now i am concentrating on reducing the number of ports.
Thanks in advence
Eyal.
  • hannes
    hannes over 14 years ago
    Hello Eyal,
    Depending on the control of yourports, it might be possible to combine multiple values into
    one port (i.e. 4 bytes into a 32-bit bus) and drive that from SPMN to your DUT. Or you could
    implement some sort of RTL driver/BFM and send a whole transaction of values to that RTL
    code to drive to the DUT.
    Best regards,
    -hannes
