  2. Functional Verification
  3. Why uvm sequence impact functional coverage database ch...
  • Subscribers 67
  • Views 15221
Why uvm sequence impact functional coverage database checksum
Arthas
Arthas over 14 years ago
Hi, I'm using v10.2s70 and my option is -uvm -coverage functional -covtest $(TEST). And I think -uvm implies uvm 1.0. The problem is, I have multiple runs which compiled separately but with exactly the same RTL files. The only differencies between these runs is I modify one uvm sequence manually. And I expect to merge coverage databases but icc complains the checksum is not match. Could anyone help to outline how to resolve it?
  • tpylant
    tpylant over 14 years ago
    Use the ‘-uvmhome <install_dir>/tools/uvm-1.1/uvm_lib/uvm_sv’ instead of ‘-uvm’ which is release dependent. By using ‘-uvmhome’ you guarantee that all simulations will pick up the same UVM release.
    Tim
