  2. Functional Verification
  3. ICC code coverage constant values
  • Subscribers 67
  • Views 15417
Binky
Binky over 14 years ago
I have a problem with the code coverage of constant values in my design.
In unit_one another one is instanciated like this:
unit_two : unit_two_name
generic map (
      A => "00110010000",
      B => "01010011100")
    port map (
      clk => clk,
      rst_n => rst_n,
      C  => C,
      D  => D,
      E  => E      );
I'm working with a testbench for unit_one.
Incisive comprehensive coverage (ICC) shows something like this in its expression report:
  Line    Index  Coverage         Expression description
   30 (   7)  25% (1/4)         F := F xor B;
                     F xor B
              <--1--->    <----2----->
            index  hit | <1> <2>
          xor ----------------------
             (   1)    0 |  0   0
             (   2)    0 |  0   1
             (   3)    0 |  1   0
Because of the constant values of A and B I can never reach the marked values.
The code coverage is now 98% but can I get 100% without marking out something?
What is the best way to deal with this problem?
Best regards,
Binky
 edit:
is it possible to exclude the embedded unit_two from icc?  The coverage for unit_two with its additional testbench is ok. The problem is only in higher levels of the design hirarchie, when unit_two is embeded.
  • Binky
     What would help is a possibility to exclude a module from code coverage. Unit_two has a code coverage of 100% but is implemented in unit_one. I know pragmas, but is there a possibility to exclude unit_two?
     example
    Kind regards,
    Binky
