  2. Functional Verification
  3. script to save waveforms into a file
  • Subscribers 67
  • Views 22220
freitas
freitas over 14 years ago
is there a way to save simvision's waveforms into a file from the SimVision shell?
From what I checked, you can save waves into a file using the menu File -> Export
But I'd like to script this task. Is there a way?
Thanks!
  • Doug Koslow
    Doug Koslow over 14 years ago
     Yes, you can use the SimVision "database export" command for this. (See the SimVision command reference manual for details on this command.)
     Thanks.
    - Doug
  • freitas
    Thanks for your reply!!
    I'm actually interested in generating a ps or png file  (i.e., an image) for documentation.
    Is that possible to script it?
     thanks.
  • Doug Koslow
     There is a "waveform print -file" command that supports printing the waveforms to a postscript file.  Again, check to docs for details.
     Thanks.
    - Doug
  • freitas
    Thanks so much Doug!
    I will take a careful look.
