  2. Functional Verification
  3. ask one question.....
  • Subscribers 67
  • Views 16327
redrabbit
redrabbit over 14 years ago
hi all,
i use define in my testcase,what i want to do is in the first loop i use the define maybe in one branch ,while on the second loop ,i want #undef the define that i defined before and into another branch,but it doesn't work......
codes are like this:
for ()
     #ifdef  AAAA then
          specman("#undef  AAAA");
    #ifndef AAAA then
why???
what really does the sentence means in reference "The effect is propagated to all files that are loaded after the
#undef statement is encountered."?
does it means the #undef could not write in just one file ? or between two import e file ,we use #undef ? like the example supported in e_reference:
#define semaphore my_semaphore;
import my_design.e;
#undef semaphore;
import external_code.e;
thank you for your reply......
  • hannes
    hannes over 14 years ago
     Hello redrabbit,
    defines are preprocessor directives. If you want control flow in your code, I would suggest using variables or AOP features (i.e. modifying method in when subtypes). The e language gives you many features, exactly for the flexibility you are looking for. Preprocessor directoves are very un-flexible, so they should be the last resort.
    -hannes
  • redrabbit
    thank you very much!
