  2. Functional Verification
  3. one question about vplan
  • Subscribers 67
  • Views 15275
redrabbit
redrabbit over 14 years ago
hi all,
i found that vplan that can be opened by eplanner could be opened by documentation tools,so i created one vplan using perl, of course saved as the .vplan,but i opened it ,which appears lots of mess .how could i fix the problem?
thanks
redrabbit
  • pcarzola
    pcarzola over 14 years ago
    Hello redrabbit.
    I don't recommend creating your own vPlan since the format will likely change from one major release to the other.
    What you may want to do is to create your plan in CSV format instead.  Take a look at the quickstart guide for more information.
    There's also a video mentioned in the Functional Verification blogs on how to do this.
    If you still want to create your own .vplan, try creating one in EP and use that as a golden reference.
    -Paul
  • redrabbit
    thank you ,pcarzola
    i've already solve the problem i posted,thank you very much for your golden suggestion.
