  2. Functional Verification
  3. Non HTML coverage report generation using E-manager
  • Subscribers 67
  • Views 15962
bharathwajan
bharathwajan over 14 years ago
 After my specman regression is complete, I am trying to generate a non-html coverage report using E-manager. When i explored the E-manager tool, I could only see HTML report generation options. Is it not possible to generate non-html reports? or atleast any work around to generate one from html?
Could anyone give me some directions?
 Thank you in advance.
  • StephenH
    StephenH over 14 years ago
    You can save a CSV (spreadsheet) from the vPlan window. Go to the menu "File->Export vPlan (.csv format)". In the dialogue box that pops up, you can choose what details go into the CSV file, e.g. full or truncated hierarchy, simulation grades, check passes and fails etc. There is also a full API called the vPlan visitor API, which lets you interact with the vPlan to generate any kind of report that you like. It is fully documented in the vManager user guide, just search for "vPlan visitor". I have used this a number of times to generate very specific report formats, usually for interacting with other tools. Have fun! :-) Steve.
  • bharathwajan
    Hi Steve, Thanks a lot for this input. Appreciate your help. I will try this. Best Regards, Bharath.
