  2. Functional Verification
  3. Cadence OCP Master BFM Oveflow error
  • Subscribers 67
  • Views 14800
Joe12
Joe12 over 14 years ago
Hi ,
While using an OCP eVC (UVM compliant) Master BFM  in between the write transactions the BFM is
throwing error " Overflow , divider cannot be zero " from the cdn_ocp_bfm_master "
JOe
  • StephenH
    StephenH over 14 years ago
    Can you please file a service request via http://support.cadence.com/ I don't think this kind of problem would be very easy to debug in a public forum as the support guys will likely need to see your log files and test code. Thanks. Steve.
