  2. Functional Verification
  3. problem about set profile
  • Subscribers 67
  • Views 14792
redrabbit
redrabbit over 14 years ago
hi all,
     recently , i ve been working on enhancing the performance for my verfication enviroment,i config "set profile" in setup().
the same seed ,same stimuli,but the results are different.
sometimes,the tb will report error just at the very beginning of run phase.
and sometimes the stimulation will complete .
the report info is like  :
***sn_prof: sample #0 failed due to running out of memory.
     try profiling with -area_size = N, where N is greater than 16777216
and i just acted on what the suggest says,
extend sys
    setup() is also
        specman("set profile -area_size = 25000000");
i don't know why???
redrabbit thank you in advance!
  • StephenH
    StephenH over 14 years ago
    Try increasing the absolute_max_size setting, as this limits how much
    memory Specman can request from the OS in total.
    Also, your settings code would be cleaner if you swapped specman("set
    ...") to set_config(). Minor point ;-)
    extend sys {
    setup() is also {
    set_config(memory, absolute_max_size, 3G);
    set_config(memory, max_size, 2500M);
    set_config(profile, area_size, 300M);
