  2. Functional Verification
  3. Functional coverage
  • Subscribers 67
  • Views 22862
Functional coverage
jxker
jxker over 14 years ago
Hi, all. I am trying to do functional coverage, but it seems something wrong with my command line, that I cannot get a functional coverage result, but only the code coverage result. Can anyone tell me where I make a mistake?
my systemverilog code is:
class rand_cov;
   rand bit[4:0] data_a;
endclass
module cov;
   int i;
   int succ;
   bit[4:0] data;
   rand_cov cov_t;
   covergroup cg;
      cov_a: coverpoint data;
   endgroup
   cg cg_inst;
   initial begin
      cg_inst =new();
      cov_t = new();
      for(i=0; i<20; i++) begin
          succ = cov_t.randomize();
          data = cov_t.data_a;
          cg_inst.sample();
          $display("data=%0d, now coverage is: %0d",data, cg_inst.get_coverage());
      end
   end
endmodule
And my command is :
ncvlog -message -sv cov.v
ncelab -message -access +rcw -covdut cov -coverage all work.cov:module
ncsim -message -covoverwrite -covtest cov -covscope cov work.cov:module
  • jxker
    Hi, all.
    I find where I am wrong. I should add "option.per_instance = 1;" in the covergroup declaration. And this enables saving the coverage of covergroup instances to the coverage database.
    And in my ncverilog version, the default value of option.per_instance is 0
    archive over 14 years ago
     Change your code as below adding:
    option.per_instance=1;
    and
        cg_inst.set_inst_name($psprintf({"%m","_cg_inst"}));
    Otherwise you'll end up with a covergroup machine generated name like: cg_inst@1_1
    class rand_cov;
    endclass
    module cov;
       int i;
       int succ;
       bit[4:0] data;
       rand_cov cov_t;
       covergroup cg;
       endgroup
       cg cg_inst;
       initial begin
          cg_inst =new();
          cov_t = new();
              cg_inst.sample();
          end
       end
    endmodule
  • jxker
    Thank you very much!
