  2. Functional Verification
  3. list generation
  • Subscribers 67
  • Views 14941
list generation
guyl
guyl over 14 years ago
I use the following code:
        var list : list of uint (bits:14);
        gen list keeping {
            it.size() == list_size_parameter;
            it.all_different(it);
to gen a list of indices, the size of a given parameter.
list size can be up to 20K, and I get a WARN_GEN_BIG_LACE as a consequence.
what may be the preferrabe way to do this in regards to memory and cpu resources?
  • hannes
    hannes over 14 years ago
    Hello Guy,
    you can ignore this warning if you do get a result that is ok for you. We continue to improve the algorithms in the generator and this should work. We are making things like this more efficient in new releases.
    Alternatively, you could do something like this:
    var all_vals := all_values(uint(bits:14));var ordered_list:list of uint(bits:14);var prev_ind:int = -1;for i from 1 to list_size_parameter {
                    gen tmp_ind keeping {it > prev_ind;it < 1<<14}; // need to add some constraints for better distribution
                    prev_ind = tmp_ind;                ordered_list.add(all_vals[tmp_ind]);};gen list keeping {it.is_a_permutation(ordered_list)};
    But with this you need to make sure the distribution of tmp_ind is good enough to give you the amount of values you need.
    -hannes
