  2. Functional Verification
  3. question about transition coverage
  • Subscribers 67
  • Views 16507
jxker
jxker over 14 years ago
Hi, all:
I have a question about transition coverage.
I have two variables, A and B, A and B both have several values. If I want to do transition coverage on the condition below:
bins[ ]  trans_cov: A(i) => A(i+1) iff ( B(i) <= B(i+1) ),  this means only when B changes to a larger value, I will do the transition coverage.
How should I realize it?
Thank you.
  • yongchen
    yongchen over 14 years ago
    could you use condition "B(i)<=B(i+1)" to generate an event and use this event to trigger your coverage?
  • jxker
    Hi yongchen,
    B(i) and B(i+1) are the same variable, but in two different time. According to you advise, I need to redord the previos value of B. Am I right?
  • yongchen
    Hi Jxker,
    I think record the previous value of B is helpful to finish this task.
  • jxker
    Hi yongchen,
    Thank you.
