  2. Functional Verification
  3. question about SVA
  • Subscribers 67
  • Views 16734
question about SVA
jxker
jxker over 14 years ago
Hi all,
I write a vunit file with SVA, I want to check a var every negedge clk, but it seems that it just check on the first negedge. Can you help me please?
following is my code:   "test_var" is a constant, and it always equals to 1
my command: ncvlog -sv -propfile vunit.v module_name.v;   ncelab -coverage all module_name;    ncsim -covoverwrite module_name
vunit vunit_assertion(module_name) {
                                                      property test; @(negedge clk) ( test_var == 1 ) ;  endproperty
                                                      cover_test: cover property(test) $display(" hit ");
  • jxker
    Hi all,
    I think I made a mistake. I find that once "cover" hit for the first time, it will not check anymore. So in the coverage report, it just hit once.
    I want to know how to make it checking during all the simulation, so the covereage report will show how many times it hits.
    Thank you very much!
  • jxker
    Hi all,
    I find the problem. I should add "-abvrecordcoverall" option in ncsim command line, this enables reporting of all finish counts for cover properties. And by default, IES reports one finish for each cover property instance.
