  2. Functional Verification
  3. Type conversion from hex String to uint (32 bits) in Specman...
  • Subscribers 68
  • Views 17948
Type conversion from hex String to uint (32 bits) in Specman e
bharathwajan
bharathwajan over 14 years ago
Hi All,
I am trying to read a file which has address and data in hex separated by space as shown below :
0001FF 0x47295784
I am having problem with converting the hex string 0001FFF to uint 32 bits and send this to my driver for further action. I have tried the following syntax from the cadence docs:
int = %{string};
int = pack(packing.low,string)
 Neither of them helped. In the both cases, the string is converted to a signed int. The doc doesnt help me convert string to uint (32 bits).
Could you pelase help me?
Could anyone please help me do this type conversion?
 Thank you !!!
 Best Regards,
Bharath.
  • danielpoe2
    danielpoe2 over 14 years ago
     what you want is specman to interpret the string as a number. You can do this easily with "<string>".as_a(uint). However you need to consider how specman wants a hex to look like, namely it should be prefixed with "0x". So if you do "append("0x", string).as_a(uint)" you should get what you want. You can try it out on the specman console as well 'print "0xcafecafe".as_a(uint)'.
    Hope this helps,
    Daniel
  • bharathwajan
    Hi Daniel,
    Thank a lot. It worked. I had tried this way but i didnot append "ox" to the string. Now it works.
    Thanks again !!!
    Best Regards,
    Bharath.
