  2. Functional Verification
  3. How to exclude bits in toogle coverage
  • Subscribers 66
  • Views 16731
sonam20
sonam20 over 13 years ago
I want to exclude bits in toggle coverage. I m working on cadence (iccr) tool.
I used this "set_toggle_excludefile" command in coverage configuration file has .ccf extension.
I created two file one exclude_bits.ccf and other one is exclude_file.dat.
contents of exclude_file.dat. file:
-ere instance test_top:i_dut_top:i_irq:i_irq_reg_map:i_regint_do c_dm_sts:shdw_q
contents of exclude_bits.ccf file:
set_toggle_excludefile ../code_cov_iccr/exclude_file.dat
But CCF file did not run.
How to run .ccf file? AM i doin correct thing?
Please do reply.
thanku
  • StephenH
    StephenH over 13 years ago
    You have to pass the CCF to ncelab or irun using the -covfile switch when compiling the design.
  • sonam20
     Thank for reply..
    I m running below command for ncelab:
      ncelab -covdut B -covfile exclude_onfig.ccf worklib test_top.sv
    but it gives below error:
    ncelab: 09.20-s014: (c) Copyright 1995-2010 Cadence Design Systems, Inc.
    ncelab: *W,DLNOHV: Unable to find an 'hdl.var' file to load in.
    ncelab: *E,NOUNIT: Unable to find a unit named 'worklib' in the libraries.
    ncelab: *E,NOUNIT: Unable to find a unit named 'test_top.sv' in the libraries.
  • sonam20
    again i m trying these below command but its did not take test_top as a top module.
     ncelab -covdut B -covfile exclude_config.ccf -message $WORK_ROOT/lib/sim/lib
     ncelab -covdut B -covfile exclude_config.ccf -message work.test_top
     ncelab -covdut B -covfile exclude_config.ccf work.src/tb/irq/test_top.sv
    ncelab -covdut B -covfile exclude_config.ccf work.test_top
    plzz reply
  • sonam20
    Where does ncelab command run ?
