  2. Functional Verification
  3. RE: How do I get nc-sim to recongnize a .sv file?
  • Subscribers 66
  • Views 14345
tpylant
tpylant over 14 years ago
If you use ‘irun’, the file name will be used to invoke the proper compiler. Otherwise you will need to call the appropriate compiler (‘ncvlog –sv’ for SystemVerilog) and it doesn’t matter what filename you provide.
Tim
