  2. Functional Verification
  3. irun & ncvlog version conflict
  • Subscribers 67
  • Views 8441
Zdeno
Zdeno over 14 years ago
'irun' utility has a different version as ncvlog:
    irun: 10.20-s073: (c) Copyright 1995-2011 Cadence Design Systems, Inc.
    TOOL: irun 10.20-s073: Started on May 18, 2012 at 13:36:57 CEST
    irun
        -f irun.args
            -ieee1364
            -access +rw
            -gui
            mux2_1.v
    ncvlog: *F,NBADVR: The version of the Calling tool "TOOL: irun 10.20-s073" does not match the version of the Called tool "TOOL: ncvlog 10.20-s072".
    irun: *E,VLGERR: An error occurred during parsing.  Review the log file for errors with the code *E and fix those identified problems to proceed.  Exiting with code (status 2).
    TOOL: irun 10.20-s073: Exiting on May 18, 2012 at 13:36:57 CEST  (total: 00:00:00)
The all package is from the new INCISIV release 2011-2012. How can I resolve the problem please?
Thank you very much in advance.
Best regards,
Zdenko Janoska
  • Zdeno
    I solved the problem already. Irun was running from other package than ncvlog. I changed the order of my search paths, Zdeno
  • FormerMember
    FormerMember over 6 years ago in reply to Zdeno
    Hi Zdeno,
    Can you share the order of search paths?
    Vedant.
  • Zdeno
    Zdeno over 6 years ago in reply to FormerMember
    Hi Vedant,
    I am sorry, but thread is 8 years old, so I am no longer using irun. For now it is xrun so I suppose you also should switch to new tools. I followed recommendations for .bashrc from guideline with no one issue.
    Best regards, Zdeno
