  2. Functional Verification
  3. automatic insertion of E2R and R2E connect modules
  • Subscribers 67
  • Views 15858
freitas
freitas over 14 years ago
I'm trying to run a very trivial example to see how the automatic insertion of E2R and R2E connect modules works. Please find the code below. Unfortunately, I get the following elaboration error:
Elaborating the design hierarchy: Top level design units: top  Discipline resolution Pass...
ncelab: *E,CUVDRF: Could not determine discipline for top.xr.
Would I be missing some elaboration option?
thanks!
`include "constants.vams"
`include "disciplines.vams"
module top;
wreal r, xr, wr;
assign xr = 3.14;
ams_electrical_src e_s1(r);
// causes insertion of Electrical2Real
// connection module
  ams_electrical_dst e_d1(xr);
// Real2Electrical connection module
  ams_wreal_src w_s1(wr);
// Coercion of SystemVerilog real variable
// to wreal
endmodule
module ams_electrical_dst(e);
   input e;
   electrical e;
  initial #10 $display("%M: %f", V(e));
endmodule
module ams_electrical_src(e);
  output e; electrical e;
   analog V(e) <+ 5.0;
endmodule
module ams_wreal_src(w);
     output w; wreal w;
     assign w = 2.5;
endmodule
  • tpylant
    tpylant over 14 years ago
    You need to have an AMS control file that at least contains the following:
    amsd {
            ie vsup=1.8
    You can also include other AMS commands such as:
    simulator lang=spectre
    rawFmtOpt options rawfmt=sst2fbin   maxwarnstologfile=1000 maxnotestologfile=1000
    saveNodes options save=all
    timeDom tran stop= 30us
    Put these commands in a file with a “.scs” extension and pass the file to “irun”.
    Tim
