  2. Functional Verification
  3. Elaboration error in SVA binding file
  • Subscribers 68
  • Views 19851
Pinak
Pinak over 14 years ago
While running the testcase with IUS 11.10.002, I am getting following error fo SVA binding file.
 ncelab: *E,NOBNDT: Bind target module not found
 Any clue on resolving this error?
Pinakin
  • Brodov Dmitriy
    Brodov Dmitriy over 14 years ago
    You can see a short help for this error by command: <nchelp ncelab NOBNDT>
    ncelab/NOBNDT =
            The above error has occurred because the target module or instance specified
            in the bind statement is not found. Check the target given with the bind
            statement in the given file name and line number.
     Can also use ncbrouse to see the error and the log file.
    May be it will help you.
  • Pinak
    Thanks Brodov ! The error is resolved because we are using ifdef macro for creating the instance of target instance and that macro we have not passed in Makefile.So during elaboration phase it won't found target instance name to bind.
