  2. Functional Verification
  3. uvm help needed
  • Subscribers 67
  • Views 20300
uvm help needed
joys
joys over 14 years ago
 I am a newbee for uvm. Looking for some understaning on using uvm_tes/uvm_env  under module.
IUS allows me using uvm_env under module but not uvm_test or uvm-agent ,  throwing below error  -
" class my_test extends uvm_test;
ncvlog: *E,FAABP1 (my_tb.sv,1|31): task, function, or assertion instance does not specify all required formal arguments [10.2.2][10.3(IEEE)]."
Follwing is the code -
module top;
class my_env extends uvm_env; //works fine
//class my_test extends uvm_test; // Gives error
// class field,function
endclass
endmodule
What should be the reason?
thanks
joys
  • tpylant
    tpylant over 14 years ago
    You need to provide the component constructor:
       function new(string name, uvm_component parent);
        super.new(name, parent);
      endfunction : new
    Tim
  • joys
    Thanks Tim !
    On a same line ,  I wanted to see how my_frame  being generated , I tried  as follow  and endup same error as earlier -
    class my_frame extends uvm_sequence_item;
    int addr;
    int data ;
    function new(string name);
    super.new(name);
    endfunction
    // field declarations and automation flags
    `uvm_object_utils_begin(my_frame)
    `uvm_field_int(addr, UVM_ALL_ON)
    `uvm_field_int(data, UVM_ALL_ON)
    `uvm_object_utils_end
    constraint addr_c { addr inside {[1:10]};}
    constraint data_c { data inside {[1:100]};}
    //function parity_calc()
    endclass
    function new(string name = "my_test", uvm_component parent = null);
    endfunction : new
      virtual task run();
       bit success;
       my_frame frame;
       frame = new("frame");
       success = frame.randomize() with { addr == 5; data == 50;};
       $display(frame);
      endtask
    endclass
    What am I missing here?
  • tpylant
    Ran fine for me using INCISIV11.10.014 (ncsim 11.10-s055).
    `include "uvm_macros.svh"
    import uvm_pkg::*;
      int addr;
      int data ;
      function new(string name="my_frame");
        super.new(name);
      endfunction
    endclass
      `uvm_component_utils(my_test)
      endfunction : new
      virtual task run();
        bit success;
        my_frame frame;
        $display(frame);
      endtask
    endclass
    Tim
  • seourani
    seourani over 14 years ago
    Thank for your help, I used success this function base on yoru help.
