  2. Functional Verification
  3. Help needed on temporal expressions with detach
  • Subscribers 66
  • Views 15723
jaichandra
jaichandra over 14 years ago
Hi everyone
     I am having trouble in writing a temporal expression using detach construct in e langauge. Any help is greatly appreciated.
    There are two events A and B in my environment. everytime B event happens A should have happened 0~3 clocks earlier.
    My temporal expression looks like below.
    expect @B => detach({@A;~[..3]})@clk else dut_error("B event error");
    In my simulation event B happens a total of 4 times. But the dut error is issued only once i.e. for the very first B event.
    I am wondering why the error is not issued for 2nd, 3rd and 4th events of B.
   I am using specman 10.2 version.
  - regards
    Jayachandra
  • StephenH
    StephenH over 14 years ago
    Hello Jayachandra.
    Your TE works fine for me, try the attached example using "irun te.v te.e -nosncomp".
    Steve.
    te.zip
  • jaichandra
    Hello steve,
                     Thanks for you help. My TE is working fine as expected. The issue was i was running the simulation in GUI mode
    without setting the ERROR_CONTINUE. The first time i get the TE error i again issue the "run" command to the simulator.
    strangely second run command to the simulator there was no more TE errors even though the event B issued 3 more times.
    Anyway when i run with ERROR_CONTINUE setting or in batch mode, error is appearing for four times as expected.
      Thanks a lot for you help and time. Have a nice day
      - regards
        Jayachandra
