  2. Functional Verification
  3. Generate random MIN and MAX value from a range of value...
  • Subscribers 67
  • Views 16325
Generate random MIN and MAX value from a range of values
bharathwajan
bharathwajan over 14 years ago
Hi All,
 I would like to know if there is any efficient way to generate a random min and max value from a range of  values?
i have a range VAL1 to VAL2... I need to generate a min_val and max_value within this range such that min_val >=VAL1 and max_val>min_val and max_val<=VAL2
I am not able to use a variable in the keep constraint.
keep MIN_VAL  in [VAL1.. VAL2]
keep MAX_VAL in [MIN_VAL  .. VAL2] -- NOT POSSIBLE
 So is there any work around without using 'gen' inside while?
Thank you !!!
Cheers,
Bharath.
  • StephenH
    StephenH over 14 years ago
    Why not just tell the solver what you just told us?
    keep min_val >= VAL1;
    keep min_val < max_val;
    keep max_val <= VAL2;
    You don't gain any efficiency from using "in" or reducing the number of constraints here. VAL1 and VAL2 can be variables or constants.
