  2. Functional Verification
  3. ncverilog simulation verilog: error fmuk
  • Subscribers 68
  • Views 29049
weebey
weebey over 14 years ago
I am trying to run a simulation on my schematic using NC-Verilog in Virtuoso. When I click simuate, I keep getting these errors:
irun: *E,FMUK: The type of the file (/counter_run1/testfixture.template) could not be determined.
irun: *E,FMUK: The type of the file (ihnl/cds0/netlist) could not be determined.
irun: *E,FMUK: The type of the file (ihnl/cds1/netlist) could not be determined.
irun: *E,FMUK: The type of the file (ihnl/cds2/netlist) could not be determined.
irun: *E,FMUK: The type of the file (ihnl/cds3/netlist) could not be determined.
irun: *E,FMUK: The type of the file (ihnl/cds4/netlist) could not be determined.
irun: *E,FMUK: The type of the file (ihnl/cds5/netlist) could not be determined.
irun: *E,FMUK: The type of the file (ihnl/cds6/netlist) could not be determined.
irun: *E,FMUK: The type of the file (ihnl/cds7/netlist) could not be determined.
irun: *E,FMUK: The type of the file (ihnl/cds8/netlist) could not be determined.
irun: *E,FMUK: The type of the file (ihnl/cds9/netlist) could not be determined.
irun: *E,FMUK: The type of the file (ihnl/cds10/netlist) could not be determined.
irun: *E,FMUK: The type of the file (ihnl/cds11/netlist) could not be determined.
irun: *E,FMUK: The type of the file (ihnl/cds12/netlist) could not be determined.
irun: *E,FMUK: The type of the file (ihnl/cds13/netlist) could not be determined.
Does anyone know how to fix this? Thanks.
  • tpylant
    tpylant over 14 years ago
    Add '-sv' to your command line options.
    Tim
  • weebey
    Thanks for the reply, Tim. I actually ended up fixing this problem with the command -default_ext verilog. However, now I am getting error messages like this one:
     nfetx  M1 ( .S(cds_globals.gnd_), .G(net11), .D(Y),
    ncelab: *E,CUVMUR (./ihnl/cds0/netlist,18|8): instance 'test.top@counter<module>.U31@AND2X1<module>.M1' of design unit 'nfetx' is unresolved in 'worklib.AND2X1:verilog'.
    nfetx  M2 ( .S(cds_globals.gnd_), .G(B), .D(hnet14),
    ncelab: *E,CUVMUR (./ihnl/cds0/netlist,20|8): instance 'test.top@counter<module>.U31@AND2X1<module>.M2' of design unit 'nfetx' is unresolved in 'worklib.AND2X1:verilog'.
     Do you know what's going on here? I synthesized the design with Design Compiler and then imported it into Virtuoso as a schematic.
  • tpylant
    Looks like you need to refer to a cell library that needs to be included on the command line.
    Tim
  • weebey
    Can I also do this through the gui in Virtuoso? If not, could you explain what I need to do, assuming I know where the library is?
  • weebey
    I was able to do the following without any errors:
    ncxlmode counter_synth.v -v ibm18.v
    where counter_synth.v is the netlist to be simulated and ibm18.v is the verilog file for my standard cells. However, I can not figure out how to do this with NC-Verilog within the virtuoso GUI still.
