  2. Functional Verification
  3. simvision plugins - tcl tk 8.5? tcl 8.4 tile? c++ qt?
  • Subscribers 67
  • Views 2935
tomers
tomers over 14 years ago
hi,
is there a way to load Tcl Tk 8.5 when writing simvision plugins?
is there a way to load the Tcl Tile package (or other Tcl GUI packages) in simvision?
is there a c++ API for writing plugins (besides the tcl API) where i can use Qt/Gtk/Wx to create the GUI ? a java API for writing plugins?
  • Doug Koslow
    Doug Koslow over 14 years ago
    > No.  The SimVision Tcl interpreter is version 8.4.  There is no way for the user to change this.
    >  Yes.   You can use the standard Tcl "load" and "package require" commands to load your own packages.  (Assuming they are compatible with Tcl 8.4.)
    > No.  The API for writing plug-ins is in Tcl and documented in the SimVision Tcl command reference.  Please note, however, that you could write your own GUI in whatever language you like and communicate with SimVision over a socket connection.  An example of using sockets with SimVision is shipped in the installation in the following directory:
    <INSTALL>/tools/simvision/examples/remote
  • tomers
    thanks.
    do you konw if there's any log where i can get more info to debug 'load' failures?
  • Doug Koslow
    Any errors from the SimVision Tcl interpreter should be displayed in the SimVision tab of the console window.
    Command output can also be written to a log file using the "-log" option of the simvision command, although you should not see anything additional there compared to the Console window.
    Thanks.
     - Doug
