  2. Functional Verification
  3. How to save the signals in waveform window?
  • Subscribers 67
  • Views 31395
rohslogic
rohslogic over 14 years ago
 Hi, I'm a newbie in NC-verilog field.
After launched the simvision, I sent some signals to waveform window from Design Browser window.
Before I quit the simvision, how can I save the signals info in waveform window, so I can load this info next time I run the simulation with simvision, instead of drawing these signals one by one from Design Browser window again.
 What's more, I wonder if there's a script way to specify which signals should be sent to waveform window. Then the specified signals will be added to waveform window automatically every time the simvision is launched, just as tcl in Modelsim?
 Thanks in advance!
  • TAM1
    TAM1 over 14 years ago
    There's a menu button for that. Use "File"->"Save Command Script" and it will write out the TCL commands that will bring you back to your current state. Use "-input" and the filename on your next simulation run to restore your windows.
