  2. Functional Verification
  3. tk plugin error in ncsim
  • Subscribers 67
  • Views 15453
NormanW
NormanW over 14 years ago
Hi, Can anyone help us?
We've already installed tk and tcl at '/usr/local/lib/tcl8.4' and '/usr/local/lib/tk8.4'. And 'libtk8.4.so' under /usr/local/lib/
But, when trying to use tk in the simulator each Tk command (e.g:tk_getOpenFile), result the below error.
tk plugin error
  • StephenH
    StephenH over 14 years ago
    Hi Norman.
    SimVision uses its own copy of Tcl/Tk which is installed inside the Incisive package. You do not need to install your own version, and indeed your local install won't be used even if you do, as the tools carefully pick up the Cadence-provided version (anything else would be a support nightmare).
    Looking at the error message you get, I suspect the problem is with your Tcl code, perhaps failing to interpret a variable properly. However I see you tried to invoke tk_getOpenFile from the ncsim prompt; this is most likely a mistake. NCsim itself doesn't have Tk built-in, instead the Tk GUI features are provided via the SimVision prompt (SimVision runs as a separate process from the simulator).
    At the bottom of the simulator's Console window you'll find at least the tabs "SimVision" and "Simulator"; switch to the SimVision tab to type any GUI commands.
