  2. Functional Verification
  3. passing events as parameters to methods or TCM
  • Subscribers 66
  • Views 14791
jaichandra
jaichandra over 14 years ago
Hi everyone,
               Is it possible to pass events to a method or TCM in e language? I have a TCM which emits events based on some register settings.
   I have five such registers and each register does the same function but on different group. Initially i thought of creating a list of events and pass the index number to the TCM and it can emit the respective event. But i belive e do not support list of events. So i was checking if it is possible to pass events as parameters to the TCM and there is nothing mentioned about this in e ref manual.
  Can someone share some information if it is possible or is there any work around? Thanks in advance for your help.
  • hannes
    hannes over 14 years ago
    Hello Jaichandra,
    events are not really types so you can't pass them. What you can do is a pass a list of structs/units which contain events. Depending on your condition you can then emit the events of the struct/unit in question. For example:
    type my_t: [T1, T2, T3];
    struct reg {
        event reg_ev;
    unit foo {
        my_regs[3]: list of reg;
        my_tcm(regs:list of reg,flag:my_t)@sys.any is {
            case flag {
                T1: {emit regs[0].reg_ev;};
                T2: {emit regs[1].reg_ev;};
                T3: {emit regs[2].reg_ev;};
            wait [1];
            stop_run();
        run() is also {
            start my_tcm(my_regs,T2);
    Regards
    -hannes
