  2. Functional Verification
  3. Specman Tutorial
  • Subscribers 68
  • Views 18273
Specman Tutorial
pravintavagad
pravintavagad over 14 years ago
Hi everybody ,
Can anybody please suggest me quickstart tutorial to  specman-e . I have knowledge of systemverilog uvm and now i want to shift to specman e. I Have specman 9.2 and above... are there any tutorials provided by cadence with the tools???
Thanks and regs,
Pravin
  • StephenH
    StephenH over 14 years ago
    Hi Pravin.
    Welcome to the Specman world! I'm sure you will like it here ;-)
    If you crank up the "cdnshelp" tool and look under the "Incisive Verification Kits" topic you will find a wealth of self-paced tutorials / workshops to experiment with. These guide you through constructing a UVM-e testbench around a simple APB-UART design and also showing the block-to-system reuse aspects by integrating the block TB into a subsystem TB.
    If you ping your local AE I'm shore they will be delighted to help you as well.
    One small point: whilst Incisive 9.2 is a very fine vintage, it is a few years old now and I would strongly recommend upgrading to a supported version such as 12.10 so you benefit from the latest additions and cool features.
    Good luck!
  • Hariharan
    Hariharan over 14 years ago
    check out ASIC site..............
  • kanth nethhula
    kanth nethhula over 13 years ago
    Hi pravin, Take any vip from incisive verification kits and then observe the code.At the same time read corresponding vip's e_user_guide.pdf. For basics refer -> Testbench.in ->Asicworld.com .............Wish u good luck
