  2. Functional Verification
  3. time between two events
  • Subscribers 67
  • Views 17205
pravintavagad
pravintavagad over 14 years ago
Hi all is there any way by which i can measure time between two events (Specman e code)??
e.g. time between two resets
  • hannes
    hannes over 14 years ago
    you have sys.time and sys.realtime. You can log the time value when an event happens (using for example and on block) and next time  you can calculate the delta.
    -hannes
  • StephenH
    StephenH over 14 years ago
    Between two different events, or two occurences of the same event? Here's an example for the latter case, I'm sure you can figure out how to modify it for the former.
    extend sys {
      !last_time : time;
      event reset;
      on reset {
        var delta := last_time - sys.time;
        print delta;
        last_time = sys.time;
  • pravintavagad
    I have start and end signals in my design. Start is asserted when burst starts and end is asserted when burst ends.
    My task is to measure the time between start and end signals. I am emmiting events on start and end. so how can i measure time between thses two events?? ( i have to continuously do this in my testbench to calculate latency)
  • StephenH
    Well, modify my example by having two "on" blocks, one for the start event and one for the end event.
    Sample the time in the start block, and compute the delta in the end block.
