  2. Functional Verification
  3. Switch to run through assertions
  • Subscribers 66
  • Views 19185
Teeeravis
Teeeravis over 13 years ago
Sim Vision is halting my simulation when an assertion fires, is there a way to force the simulator to fire the assertion but continue running.
I have tried this switch(-assert_logging_error_off) which seemed correct but It didnt work
Most of the switches I have tried completely disable the assertions.
Any assistance  would be appreciated
  • Doug Koslow
    Doug Koslow over 13 years ago
    This command should do what you are looking for:
    ncsim> set assert_stop_level never
    - Doug
  • Teeeravis
    Thanks Doug,
     I'd stumbled upon this  /forums/p/8624/8646.aspx#8646
    That is definitely the right command.
    I would like to apply the command in the ade-l setup once, ive applied other switches under  Simulation->options-> ams simulator
    Under the main tab additional arguments, i cant get it to take there unfortunately.
    I'm beginning to think that is not the location to be applying the switch,  Should I be applying the switch elsewhere or is there some special syntax.
  • tpylant
    tpylant over 13 years ago
    You will need to put the command into a test file (like assert.tcl) and then call it with a “-i” command line option to the simulator, i.e. “-i asset.tcl”)
    Tim
