  2. Functional Verification
  3. irun: design.v is verilog and verilog AMS
  • Subscribers 66
  • Views 16321
moogyd
moogyd over 13 years ago
We are migrating to an irun based flow to simplifiy our compile/elab/sim flow, and have a slight issue.
We have a file design.v, containing module design. Depending on a define, this can either be a standard digital module, or a WREAL model.
i.e. Within the file
`ifdef WREAL
wreal sig_name;
 `endif
This issue is that irun uses the file extesion to infer the type of file, in this case, it does not work.
This is a non-trivial design, so I have multiple verilog, vhdl and vams files, and using the -ams is probably not an option.
Question is: Can anyone suggest a solution? Is there an command line option that I missed, which applies to a single file only?
Thaks,
Steven
  • tpylant
    tpylant over 13 years ago
    A few thoughts:
    1. Rename the file with a “.vams” extension. Since Verilog-2001 is a subset  of Verilog-AMS, the syntax should compile correctly whether you have the WREAL defined or not.
    2. If for some reason you can’t rename the file or you use SV in the non-wreal code, then you could use a unique filename extension (eg. .sv-vams) and then use “=amsvlog_ext +,.sv-vams” for when you define WREAL or “-sysv_ext +,.sv-vams” for when you don’t define WREAL.
    3. If neither of those work, you could just compile the one file by itself and use the “-ams” switch when you define WREAL and then compile the remaining files using your standard irun command.
    Tim
  • moogyd
    Hi Tim,
    Thanks for the ideas
    1) This would solve the immediate issue. We are currently not using SV, but will be in future. However, I guess that we would not be mixing wreal and sv in the same file.
    2) Extra marks for "thinking outside the box", but no thanks :-) I don't think this solution would make me very popular within the company.
    3) I had thought of this, but we would then start losing irun advantages.
    One more thought I had is to use a verilog pre-processor+Makefile to auto-generate design.vams from design.v
    For now, I'll go with (1)
    Thanks again for the feedback.
    Steven
