  2. Functional Verification
  3. Facing Error while running specman test
  • Subscribers 67
  • Views 17111
mdkaleem
mdkaleem over 14 years ago
I am facing the below error when i run the specman test,please do let me know is this problem w.r.t environment variable settings.
Compiler version D-2009.12-2_Full64; Runtime version
D-2009.12-2_Full64;  Nov  2 16:19 2012
failed to dlopen
/apps/cds/incisiv/9.20.033/SPMN92/specman/linux64/libsn_mm.so:
/apps/cds/incisiv/9.20.033/SPMN92/specman/linux64/libsn_mm.so: undefined
symbol: sn_global_method_indices
Regards
kaleem.
  • Avi Farjoun
    Avi Farjoun over 14 years ago
    Check your environment setting are pointing to the correct location.
    Specifically check LD_LIBRARY_PATH, SPECMAN_DLIB or if you are running with irun -snshlib  than check that the libraries you used to point at are relevant now.
    Regards
    Avi
  • mdkaleem
    Im using the below command to invoke the tool and to run the test.
    specrun -p "load test.e;test"  specman_build_path -ucli -i specman_run.do -l specman.elog
    and i dont have SPECMAN_DLIB env variable set.
    Regards
    kaleem.
  • StephenH
    StephenH over 14 years ago
    It looks like you're using Specman with VCS, so be careful to check that the Specman version you're using is compatible with your VCS version (look in the cdnshelp documentation tool for this). As you're using quite an old version I can't recall what was supported at that time.
    How did you build the vcs-specman executable and did you accidentally change something in your env between building the executable and trying to run specrun?
