  2. Functional Verification
  3. vcs_specman not created
  • Replies 13
  • Subscribers 67
  • Views 22558
mdkaleem
mdkaleem over 14 years ago
I am trying to create an exe using vcs and specman,
initially specman and vcs compilation went through fine and when the vcs simulation started i got an error saying as below,please let me know further what to do??
sn_compile.sh: /apps/cds/incisiv/10.20.122/specman/bin/link_vcs.sh failed
and this are the warnings i see
if [ -x ../scr_specman ]; then chmod -x ../scr_specman; fi
g++  -o ../scr_specman
/apps/denali/mmav_purespec/3.2.068_64/verilog/denverlib.o -Wl,-E
-Wl,-whole-archive    -Wl,-no-whole-archive
/apps/cds/incisiv/10.20.122/specman/linux/specman__main_.o
_vcsobj_1_1.o  5NrI_d.o 5NrIB_d.o SIM_l.o    rmapats_mop.o
rmapats.o      /apps/synopsys/vcsmx/2011.03-SP1/amd64/lib/libvirsim.so
/apps/synopsys/vcsmx/2011.03-SP1/amd64/lib/liberrorinf.so
/apps/synopsys/vcsmx/2011.03-SP1/amd64/lib/libsnpsmalloc.so
/apps/novas/debussy/2009.07/share/PLI/vcsd_mixed_latest/LINUX64/pli.a
-lpthread -ldl
/apps/cds/incisiv/10.20.122/specman/linux/libctype_compat.a -lm -ldl
/apps/cds/incisiv/10.20.122/specman/linux/libspecman.a
/apps/cds/incisiv/10.20.122/specman/linux/libvcs_sn_boot.a
/apps/synopsys/vcsmx/2011.03-SP1/amd64/lib/libvcsnew.so
/apps/synopsys/vcsmx/2011.03-SP1/amd64/lib/libuclinative.so
/apps/synopsys/vcsmx/2011.03-SP1/amd64/lib/vcs_save_restore_new.o -ldl
-lm  -lc -lpthread -ldl
/usr/bin/ld: warning: i386 architecture of input file
`/apps/cds/incisiv/10.20.122/specman/linux/specman__main_.o' is
incompatible with i386:x86-64 output
/usr/bin/ld: warning: i386 architecture of input file `rmapats.o' is
`/apps/cds/incisiv/10.20.122/specman/linux/libspecman.a(specman_all_.o)'
is incompatible with i386:x86-64 output
`/apps/cds/incisiv/10.20.122/specman/linux/libvcs_sn_boot.a(vcs_sn_boot.o)'
Regards
kaleem.
  • Avi Farjoun
    Avi Farjoun over 14 years ago
    You are probably trying to compile a 32 bit application on a 64 bit machine.
    please check the attached solution:
    http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:ViewSolution;solutionNumber=11219078
    Good Luck
    Avi
  • mdkaleem
    mdkaleem over 13 years ago
    Hi
    Avi,I am not able to access the above link.how ever i tried to compile on 32 bit machine but i see that vcs does not support 32-64 bit cross compilation.
    kaleem.
  • Avi Farjoun
    Avi Farjoun over 13 years ago
    Hi Kaleem
    I copy the solution below:
    Error Message
    Error message could like one of these:
    ld: warning: i386 architecture of input file `/sw/linux/stildpv/lib/libstildpv.a(dpvdone.o)' is incompatible with i386:x86-64 output
    ld: warning: i386 architecture of input file  `/sw/linux/stildpv/lib/libstildpv.a(dpvparopt.o)' is incompatible with i386:x86-64 output
    collect2: ld terminated with signal 11 [Segmentation fault], core dumped
    /usr/bin/ld: warning: i386:x86-64 architecture of input file
    `/usr/design/rtl/c_block/c_intf_code.o' is incompatible with i386 output
    Problem
    User wants to compile a 32-bit shared library and executable on a 64-bit machine for use with IES product ( ncsim or specman or etc. ) but gets an error about incompatibility.
    Solution
    When running a 32-bit version of IES on a 64-bit machine, there are a couple of items to be aware of in using the gcc compiler.
    1)  there are switches to control the binaray output as 32 bit or 64 bit.     The switches -m32 and -m64 explicitly control the output type and it is recommended they always be used as a mean of self-documentation for the intent of the compile command line.
    2) On x86_64 architecutre machines the DEFAULT is to give 64 bit output as if -m64 was present on the command line.  On i386 or i686 machines the DEFAULT is to give 32 bit output as these machiens are incapable of generating 64 bit output at all.
    For any C code with IUS or Specman usage:
    If the user has their own C code (PLI, VPI, VHP, or /DPI ) to compile and link into the simulation,  they will need to ensure that the object file created is also 32-bit compatible if they want to use the 32 bit IES executables.
    Typically a user will compile their C code on an 64 bit machine just as they would while running on a 32-bit machine.  The user will need to add the "-m32" switch to their gcc compilation in order to produce a 32-bit compatible object file.
    UNIX> gcc -m32 <C code> <options>
    Then they can load the shared object dynamically  ( if that is the approach they have ) or continue to link a static executable using the 32 bit *.o files they have created with the gcc command.
    For Specman sn_compile script:
    there is a setting within the system.specman file which forces the sn_compile.sh script to compile in 32-bit mode using a "-m32" switch.  This will guarantee that the executable or shared object file produced by the sn_compile.sh is 32-bit compatible.
    # Force 32-bit Specman on 64-bit Linux machines case `uname -m` in  x86_64)
       SPECMAN_CCOMPILER="gcc -m32";
       SPECMAN_LINKER="gcc -m32";
       SPECMAN_SHLIB_LDFLAGS="${SPECMAN_SHLIB_LDFLAGS} -m elf_i386 -L/usr/lib";
       SPECMAN_LDFLAGS="-Wl,--undefined=__ctype_b
    $SPECMAN_HOME/linux/libctype_compat.a ${SPECMAN_LDFLAGS}"
    esac;
     Avi
  • mdkaleem
    Avi,thanks for copying the solution,i checked in my system.specman file and i see that the below code exists but i am not sure whether it is taking these parameters or any default setting parameters .
    kaleem.
  • mdkaleem
    Avi,
    Or do we need to force this parameters separately while sourcing our specman scripts?
    Regards
    kaleem.
  • Avi Farjoun
    Looking back now at your first response today - Is there a chance you are using 64bit VCS with 32bit Specman?
  • mdkaleem
    Avi,
    i am using both specman and vcs in 64 bit only..
  • Avi Farjoun
    Well, you are not using Specman 64bit, and that is the source of the problem. you can either setenv SPECMAN_AUTO_64BIT or use the -64 flag when invoking specman or sn_compile.sh To ensure you are actually using the 64bit version (make sure you have it installed beforehand...) Avi
  • mdkaleem
    Avi i did set  SPECMAN_AUTO_64BIT as setenv "SPECMAN_AUTO_64BIT ALL" and when i checked specman
    version using specman -version command , i see that specman(64) in the terminal.I hope this confirms your doubt?,i have also conifrmed
    the same with cadence support team.
    kaleem.
  • Avi Farjoun
    Hi Kaleem
    In this case it seems like a support issue indeed.
    Please give me the SR number, I'll try to help the person that handles that...
    Avi
